Would a faulty glow plug bring on the engine management light?
stevo2603
My engine management light came on the other day and today was the first day I could get my car put on a diagnostics machine. The fault found was with one of the glow plugs, so I've now ordered a new set of glow plugs.
I didn't think that it would, as I've changed faulty glow plugs before on a car and they hadn't brought on the engine management light.
Steven
stevo2603
Thanks for the help. I thought I'd better check on here just in case there was another fault that was somehow not picked up. :lol:
Calyx
Yes it does. If you can scan it on VagCom it will tell you the cylinder its affecting as well. This happened to me:
17057/P0673/001651 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
Possible Symptoms
* No Pre-Glow Period
* Poor Cold Starting
Possible Causes
* Glow Plug Wiring faulty
* Glow Plug faulty
Possible Solutions
* Check Glow Plug Wiring
* Check Glow Plug
stevo2603
The diagnostics machine used told them it was cylinder 1 that was affected. So I know what one needs changed, but I'm going to change them all to save any hassle.
Cupra TDI 150
287
This happened to mine originally it was cylinder 3 so changed all 4, now 5 months later cylinde 2 is showing up the fault? Can't be a faulty plug as it only 5 months old
Jan 22, 2007
2,074
some may say lala land....
it will be the harness now
there is a long thread on this in the tdi section that covers this complete with guides and aprt numbers
1st time = change plugs
2nd time = change harness
never had an issue yet and i did the harness myself & garage the plugs.
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
be very carefull if you are changing the plugs yourself. one of mine started spinning on the threads coming out.. cost me over 500 euro in the end
