workshop manual for 02m fzq
Shmoo
224
Berwick upon Tweed
hi, I am lookin for the above. can anyone direct me to a place to get on. I am planning on replacing my gearbox bearings but need shim clearences for all of the bearings. thanks
Shmoo
224
Berwick upon Tweed
hi there I've not currently had a chance to look. I have been trying to access it via my iphone but it does not support the format. I will get my laptop fired up tonight and have a look. I'm sure there will be info there that I will need. thanks
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
I think Elsawin is the only source of this information. The Haynes Golf Mk.4 manuals wimp out on gearboxes, reckoning they are too difficult for the DIY mechanic.
The VAG self-study program is interesting but contains no maintenance info.
8bit
3,401
Aberdeen
You could try posting on VWVortex, it's a US forum but there are a lot of very knowledgeable people on there, I've sometimes had better results asking more obscure questions (no offence!) on there than on here. Reasonable chance someone will have a Bentley manual for a car with the same gearbox and look it up for you. Also worth searching there, lots of good historical info.
Shmoo
224
Berwick upon Tweed
thanks kindly. do you know if the bearing clearences are the same on all 02m gearboxes. I have access to the manual for the old Octavia which has 02m gearbox and could use that as a guide?
csd_19
2,280
28
Angus / Edinburgh
Checked a couple of gearboxes and the shims list as the same as those above - I can't see why the clearances would be any different between the 02M boxes, basically the same with a couple of different F/D ratios.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
You need a manual with the adjustment procedure in it. The input shaft should have a clearance, but the layshafts are under compression.
