workshop manual for 02m fzq
Shmoo
224
Berwick upon Tweed
hi, I am lookin for the above. can anyone direct me to a place to get on. I am planning on replacing my gearbox bearings but need shim clearences for all of the bearings. thanks
Shmoo
224
Berwick upon Tweed
hi there I've not currently had a chance to look. I have been trying to access it via my iphone but it does not support the format. I will get my laptop fired up tonight and have a look. I'm sure there will be info there that I will need. thanks
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
I think Elsawin is the only source of this information. The Haynes Golf Mk.4 manuals wimp out on gearboxes, reckoning they are too difficult for the DIY mechanic.
The VAG self-study program is interesting but contains no maintenance info.
8bit
3,401
Aberdeen
You could try posting on VWVortex, it's a US forum but there are a lot of very knowledgeable people on there, I've sometimes had better results asking more obscure questions (no offence!) on there than on here. Reasonable chance someone will have a Bentley manual for a car with the same gearbox and look it up for you. Also worth searching there, lots of good historical info.
csd_19
2,280
28
Angus / Edinburgh
Input shaft shims:
Differential shims:
Couldn't see much else regarding shims in the two mins I had to check lol :)
Shmoo
224
Berwick upon Tweed
thanks kindly. do you know if the bearing clearences are the same on all 02m gearboxes. I have access to the manual for the old Octavia which has 02m gearbox and could use that as a guide?
csd_19
2,280
28
Angus / Edinburgh
Checked a couple of gearboxes and the shims list as the same as those above - I can't see why the clearances would be any different between the 02M boxes, basically the same with a couple of different F/D ratios.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
You need a manual with the adjustment procedure in it. The input shaft should have a clearance, but the layshafts are under compression.
