Wont start after bump??
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
Hi folks sorry that this thread is about a golf mk4 but think i might be useful as presume the same sensor would be same on a Leon.
Right my mate bumped his golf 20vt today and now the car wont start and had to have it towed home, but the guy that picked it up reckons that there is a sensor (knock sensor maybe!?) on them to cut the fuel pump in a bump. Anyone heard of this and know where it is and how to resolve it. The car doesnt have much damage to be honest so should be starting.
Cheers all
D3DNA
391
Cov
There is a cut off switch to kill the ignition and fuelling in some makes and models of cars. Not sure about where it is or the reset but needs to achieve a certain G before triggering.
dainott2105
Nov 4, 2006
685
swansea
cheers, guess it must be under the bonnet somwhere on the fuel line but just wondering if anyone knows where it could be. Its a nightmare cos the car is drivable but just cant start it.
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
I have had a look on Autodata and carnt find an inertia fuel cut off switch anywhere on the leons or the golf range. so maybe its another problem good luck sorting it out
dainott2105
Nov 4, 2006
685
swansea
mmm! bit of a strange one then. cant understand it to be honest unless the bump has popped a fuse or relay (as DPJ says). Take it the relay is under the bonnet on the passenger side? Reckon the drivers airbag going off might have something to do with it then?
You reckon fault might show on Vag-com then?
dainott2105
Nov 4, 2006
685
swansea
cheers for the help and info lads il have a look this week for some info and see if i can find anything on vag-com and post it on here for reference.
ARCH 150 FR
hello mate most cars have a battery cut off on the possative battery terminal that breaks a contact when the airbag has gone off cuts the power to various ecu,s its usually under the red plastic cover.
