my climate control has went wonky! when I set it at auto 21 the fan speed adjusts as i should but when warmer than 21 it doesnt bring the a/c in, I need to press the a/c button. Also for example if I were to leave it set at fan level 2 and 22 degrees then turn off the ignition then back on it will go straight to auto and the fan will jump up to level 4. Also my ambient air temp is reading incorrectly, it maybe a faulty sensor but wonder if these problems are related?
HELP!
HELP!
