Windows roll down feature
stokeballoon
141
Deepest Darkest Somerset
I know you can open the window from the remote, I have tried with mine, but only the drivers window opens, is this normal, or will I have to get it "enabled" by the dealer in order for them all to roll down? Also can i have the Sunroof in on the feature?
The sunroof is enabled to auto close, but does not auto open.
Any thoughts?
SB
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
Mine opens all windows.
Wonder if this is a setting in the bluetooth menu somewhere.
(anyone know what each setting does??)
Glovepup
Cupra Lova
May 27, 2006
450
Sevenoaks, Kent
Mine all open and shut, had a look in the menu system on the mfd the other week to see what options are available but could not find anything with regards to windows.
SMC_SeatWindsor
if i remeber i beleive its in the conveniance (sp) section of the menu
Tam
Feb 10, 2005
1,777
Near Reevo :)
out of curiosity, why would you want to open the windows from the fob anyway?
Well, I thought that too, but I have used it SOOO many times in the last few days when its hot, just to let the heat out before you get in.
+ it looks smart when you walk up to your car ;)
stokeballoon
141
Rob,
sorry for the late reply, but work and not having the car close.
1. enter the menu section by holding down the rocker switch on end of wiper stalk
2. scroll down using rocker switch to Lights and Con menu
3.confirm using button underneath.
4. scroll down to conv mode menu
5. confirm as at 4
6. select all
6. select back and exit back up to MFD mode
7. sorted!
Hope this helps
Dave
tobywuk
83
just tried it and it dosent work.
i have the 1.9 tdi stylance, do i have to have the conveniance pack or something?
Rob GTI
544
South Wales
Rob,
5. confirm as at 4
6. select all
7. sorted!
Hope this helps
Dave
Got that enabled as above and all the windows drop but the sunrood dosn't open.
tobywuk
83
i have the bluetooth option in my car but holding the lock or unlock does not work. any ideas?
