will this turbo fit my ibiza pd 100?
JamieLad!
hi, im a new member and this is my first post so be nice! i have a 02 seat ibiza 1.9tdi pd100. im getting a 130 conversion done so im looking for a pd130 ecu, intake manifold, and turbo. ive found a pd130 turbo from a mk4 golf and want to know if it would fit ok? model# GT1749VA. any help much apprecieated!
jamie :p
JamieLad!
turbo
yea think i will do that aswell. so will that turbo suit my car ok? so that i dont discover it doesnt fit when i buy it.
Aug 1, 2005
2,695
Cullompton . Devon
jamie :p
When you say a "130 conversion done" you talking about fitting a PD130 engine or just taking your car to 130bhp? If your just fitting a PD130 turbo why do you want a PD130 ecu ?
JamieLad!
turbo
hi, im planning to keep the pd100 engine but add 130 turbo, ecu, injectors, inlet manifold. i was told that the 130 ecu would be better than the 100 ecu because it could manage the turbo better and would be re-mapped better. any ideas on this? :confused:
JamieLad!
ok im getting the turbo. ive been told that i would need a remap for it to work properly. will i need to get new injectors? will i need to get a different ecu or will the one i have be ok?
jamie
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Do NOT swap ECUs - you'll have all kinds of trouble. There's no difference between yours and another, apart from a 130 ecu will probably be set for a 130 car with different specs, etc. When it comes to remapping, make's no difference if you map a 130 ecu or a 100. As long as the hardware is up to it.
JamieLad!
ok ill leave the ecu. what about injectors? im guessing the existing ones wont be good enough. what would be a suitable upgrade? ive been lookin on ebay and there are a good few but dont know what type would suit.
jamie
Aug 1, 2005
2,695
Cullompton . Devon
You might want to talk to Maxcars1 as he has done all this stuff and looked into most other things that can be done to upgrade a PD100. Injector you need PD130/150 doesn`t matter what car. Don`t pay more then £100-200 for secondhand injectors though.
