Will cupra do 60 in second gear?
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
Basically as title says ,
will the Cupra do 60 insecond?
reason im asking is i have problems with my car.
Just another measure really.
Rob.
Al
7,331
9
I am curious - Why would top speed in 2nd gear be indicative of helping figure out if the car has a problem? :confused:
Al
7,331
9
52mph is just in to the red line as memory serves. As gearing is going to be the same on any cupra with a standard gear box, one would assume there is a problem.
How fast does it go in 1st and 3rd?
Jan 18, 2007
518
West Of London
Check the gear ratios. 2k in 6th gets you to 50mph. Use that as a reference and work back the maths for 2nd gear and that will tell you what you can get without taking into account wind & rolling road resistance.
saintsfanno1
49
This surprises me, I don't hve a Cupra just a mere FR170 TDi.
However my old Focus ST170 I am sure used to easily pull near 70 on the limiter, and a Cupra can't????
It surprises me, thats all.
saintsfanno1
49
Just means the Cupra has a shorter second gear - did the ST170 run a 5 speed 'box?
I agree but I am just surprised it is designed this way in terms of optimum 0-62 performance. The fact that you have to waste time changing gear to 3rd to get there??
No my ST170 was standard, not bulefinned and had a 6 spped box.
chrisboyle999
MFD3 for sale, inbox me.
Nov 28, 2006
1,838
Geordieland
just dug out a few facts and figures and with an online calculator found that theoretically the cupra can do exactly 60mph in second, before you factor in road resistance etc.
but to do a 0-100kph (62mph) you will definitely need 3rd.
(the above assuming engine limited at 7100rpm)
Jul 10, 2007
1,267
Leeds
This is what makes 0 - 60 or 0 - 62 a bit of a pointless measure, the figure is dependent on whether or not you need to change into 3rd as the fact you need to change gear twice will make the 0 - 60 time slower.
