whos fitted a 150 turbo to a lesser engine?
BIG4244
51
Dartford kent
as above, just fitted one to my 104 pd, getting mapped soon, anyone else done it, and if so what other bits have you changed? injectors? cheers
brad1
the injectors from a pd130 or 150 should fit and also a turbo for a 130 or 150 will fit
is that your answer?
BIG4244
51
Dartford kent
They do, its in a caddy! ive fitted the turbo which required a different flange welded to my original cat, i just wanted to know if my standard injectors will be upto the job?
brad1
on a similar question does anybody know if either a pd130 or pd150 turbo will fit a mk4 ibiza tdi 1.4tdi pd75
manifold may be different if I beleive as yours in a 3 cylinder and ours in a 4 cylinder so you may be able to if you can adapt the turbo to your existing manifold
brad1
Ive heard they are a straight swap onto a 110 non-pd, are they?
yeah but to get the best out if the turbo you need a fmic, bigger injectors/nozzles, 150 egr valve and a decent exhaust system
T. Spark
ECU16 on a VW Caddy which is 105PS (around 104bhp!) is the vehicle in question I assume.
In which case, a remap will see 155bhp and 260lb.ft. With a 150 turbo on and nothing else upgraded youd see the same as the injector cycle would be pretty much maxed out after those figures.
brad1
on the smaller engines such as the pd100 and the tdi 90/110, the injectors are one of the restrictive parts as TSpark says, thats why ive got t4 nozzles 502 waiting to go, should see 155-160 on standard turbo :D
T. Spark
Yup, a little more can be got from the newer ECU's and a mate of mine just had his caddy mapped yesturday to the above figures, well 154.8bhp and 263lb.ft give or take.
brad1
some good results there, so tspark, are sfs, or have they got a uprated silicone replacement pipe for your car?
BIG4244
51
Dartford kent
yeah its a caddy, 1.9 tdi 2005 chassis, BJB engine number, can i upgrade the nozzles on P.D. injectors or is it easier trying to get some 150 injectors?
brad1
either injectors form a pd130 or pd150 as i think the injectors are the same if someone wants to confirm that
BIG4244
51
Dartford kent
Just out of curiosity are the 130/150 injectors held in by a retaining block that you have to set up with a vernier gauge and D.T.I. gauge or ones that have a bolt either side??? cheers
brad1
not sure on that, maybe one of the PD boys will be along soon to give you the answer ;)
