White Gunk
Yumann
1,638
Glasgow
Anyone know what this suggest? I have white gunk on my oil cap
The only thing that comes to mind is a dodgy thermostat cause the car never reaches temperature anymore only gets to a 1/4 on the guage when it use to be 1/2.
Could this be causing the oil not to reach temperature causing the gunk?
Steve_B
Stacy mmmm.......
May 6, 2005
241
West Yorkshire
Check the oil levels as well, if you've run the oil low and take the engine to high revs frequently then you can get the gunk on the oil cap. Had the gunk problem on my last car which I didn't check the oil levels on regulary and gave a bit of a thrashing.
matt_s
4 8 15 16 23 42
Dec 23, 2004
654
19
If the car isn't getting up to temperature along with the current cold wet weather you just get a bit of condensation in the engine. Same as doing short journies. If you sort out the temperature problem the gunk should disappear. If it doesn't then start to worry.
Yumann
1,638
Glasgow
I was waitn gor that one guys!
Thing is I have been doing long journeys and the car just never heats up properly according to the temperautre gauge.
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Had the exact same thing on my old 1.4 engine flush and an oil change fixed it, just due to so many 4 mile journeys to work that a bit of condensation build up occured. I wouldnt worry my mums 1.4 polo has had it for 4 years now :)
Yumann
1,638
Glasgow
Neh the oils looks fine scotty.
Its always had it on the cap but seems to be getting worse. Must be the time of year cause its cold and wet. And neveres reach full operating temp
Going to test the water temp in the next few days. Accord to the sevice manual its meant to be between 84 - 98c
mik
irregular participant
Jun 26, 2001
3,012
Glasgow UK
Jeez that is an alarming picture - where the **ck did you get that carpet? :blink:
As per the suggestions - most likely to be your "underheating" issue.
Triple D
I would have said if its in the oil cap, check the dipstick and if its on that too then it might be the head gasket.
Yumann
1,638
Glasgow
I am using 10-40 oil
As for the breather that could be it cause i remember doing the filter and seeing gunk on the breather pipe.
As for the carpet its old peice in the garage Mik :)
