Hi folks. I have a 2003 Seat Leon mk1 1.6 litre petrol 16 valve, AUS engine.
I'm getting error code P0445: Evaporative Emission Control System Purge Control Valve Circuit Shorted .
Is this the "N80" valve? Where would I find this in the engine bay, please? A photo with a nice arrow would be worth a thousand words!
Symptoms are that the car refuses to start; it turns over fine but just won't get running.
Car had this problem a few months ago; towing it and laying it up for a few days seemed to solve the problem. In the mean time I also changed the MAP sensor. Car then ran a bit lumpy but otherwise OK until now.
So it was running fine, then I filled the fuel tank this morning, then after a short drive it refused to start. Which also leads to the conclusion that this is some kind of fuel evaporation issue, so looking good for the evap purge control valve, right?
Now I think should be looking for a wiring fault somewhere near the N80 first, before I try replacing the N80... but I still need to know where the damned thing is please!
Also does this N80 thing have a fuse, if so where please? Admittedly if it's detecting a short circuit then it can't be a fuse, can it?
