when to cut my losses?
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
just a question it may be nothing but has me thinking
got a 1.4 99 plate done 76k never had a problem, needed an exhaust when i got it and a cat to pass its first MOT but other than that been little bits
anyway recently over the last few months i have noticed my radiator bottle has been loosing water, its not drastically bad as i did not check for a while till the weekend but was well below min at the time
normally this is a sign of a leak, now its probably not serious and will be fine and i haven't seen pools of water or other fluids under the car. but this along with tired suspension which i don't really want to change unless needed, cost for the lot i can't afford currently and i reckon is just tired.
can't afford to buy a new car outright as i have before would need to be a loan, so when would you guys call it a day?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
annoyingly the bloody things keep going....... only having 'severe' issues when neglected
relatively cheap to fix (verging on the silly cheap if you DIY)
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
yeah suspension has always felt odd though, i had a 97 plate 5 door 1.4 i wrote off and that was brilliant to drive because i could feel the road through the steering wheel
current one i can't feel the road through the wheel at all, most of the feel is through the body of the car. it drives well as its on wider tyres but it would be fantastic if i drove like my old ibiza but it has not since day 1 i had it
the radiator problem dosen't seem too bad at hte moment, its not loosing water fast and it took me several weeks to notice the current drop so if i keep my eye on it then it should be fine
