when i start i get a flashing yellow oil light whats it mean?
Joe_Cupra-R
I have the same problem and i'm still not sure what it is. There doesn't seem to be a definite answer anywhere but my feeling is it's warning of a problem with a sensor, oil pressure possibly? rather than an actual warning of low oil pressure or level as I would expect this to be a "stop the damn car now" kinda warning. Even so i'm gonna get mine looked at and see if it's logged a fault code. If I get it done soon I will post up my findings.
Pyro
It's oil pressure warning it does say it in the Manule ;)
When I had this it was the oil pick up!! It was blocked and full of gunk and **** there common on these cars wip off the sump take the pick up off and clean it with fuel give the sump a good clean to aswel if its not the pick up then you need a compression test asap ;)
That what mine was anyway if you keep running it then say bye bye to the head :(
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
It could be the sensor, or may be its time for an oil change. I had this happen to me and i have a oil pressure gauge and had changed the oil pick up pipe, so knew there was no oil related problem Vag- Com showed nothing either. it eventually went away.
jamie8954
Diesel FTMFW
Jun 29, 2008
553
UK
i had simular recently on my golf but i have full fis so it read " oil sensor workshop " and " Stop Oil Pressure Stop Motor "
it was a dodgy wire on the oil sensor on the bottom of the sump.
srherman
oil light flashes yellow for about 3-4secs then goes off.
Has anyone got an answer for this dam oil light flashing yellow for approx 3-4 secs before i start the engine?! it doesnt always do it just now and again,it only flashes before i start the engine.HELP! no strange noises or overheating of engine etc.temp is normal and car running fine. :confused:
srherman
Flashes yellow (defective oil level*
indicator)
If the oil level indicator is defective an
acoustic signal will sound and the warning
lamp will flash several times.
From the moment of the defect to the
check-up of the engine the oil level needs
to be checked regularly, preferably when
filling the tank.
I do not get an acoustic sound warning, just flashes for few secs then goes off. got to be an intermittent oil level sensor fault.
