Hi all, sorry to dig up an old thread. If I went with 10mm/15mm spacers can I stick with my original bolts and locking bolts? reason being to keep the original lockers really. If not what is the max I could get spacer wise with standard bolts?
Hi mark,
I was told that 5mm is possible with standard bolts but any more and it's new bolts all round.
Standard bolts are around 25mm thread length so if you have 10mm spacers you will need 35mm bolts.
You can buy new lockers with a longer thread.
I believe that 5 full thread turns is what Is recommended for your wheel bolts.
There are varying bolt types I.e. Radius bolts that normally come on standard wheels and tapered bolts that are more common on aftermarket wheels.
If possible buy hub centric spacers which come with the correct diameter lip for your wheel to sit on, I think 57.1mm is the correct diameter for this lip.
I've not sorted mine yet as I'm trying to work out if I can buy one set of locking nuts to cover both the 15mm and 10mm spacer.
Also so far I've found that 11mm and up offer hub centric so you may need to go 15mm & 11mm.
Lee
