Wheel bearing gone??
danderton
hi, i have a leon 19.9tdi se 2001, recently i have been getting a grinding noise (metal on metal sound) when i turn right and low speeds, very noticeable at roundabouts.
i have replaced the front pads and discs as these were worn and wondered if had warped discs but the noise is still there?
coukld it be my wheel bearings? or any other ideas?
thanks
dan
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
The metal plate behind the discs might be catching on one side, poke a screwdriver through to push it back slightly then road test it.
Feb 26, 2009
5,275
Wolverhampton
thanks
dan
That sounds more like a CV joint to me rather than a wheel bearing? Get your wheels on full lock and have a poke at the gaitor, see if it's cracked or leaking.
It could be a wheel bearing, but the noise would be worse at high speeds.
danderton
ok thanks, i will have a look, would there be much of a leak? and would this be when only turning right?
danderton
cheers how urgent is this to replace? should i still be driving it?
danderton
is this a easy repair or would i have to go to the garage? expensive? thanks for the help
MJ
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
A worn cv joint makes a clicking noise not a metal grinding noise, its a 6 piece bearing so there are gaps between the ball bearings - hense the clicking, if its so far gone that its turned to swarf and mush then it might make a grinding noise but the car wont be driveable.
