What to change at same time as headgasket?
platofan
218
Waterpump and cambelt kit?
Car has done 107k and the service history says it had the belt done at 70k.
It's a PD130 sport.
red_october
Maybe the thermostat or at least check its working properly?
platofan
218
Thanks guys, thermostat it is then. :)
Only had new oil and filter a week ago. :( Car better had behave for the rest of it's life.
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
Get the air intake manifold and EGR spotless, while you there get the intercooler and pipework cleaned!!! Tends to smoke loads less and will be better on diesel too.
air121005
1,609
Worcestershire
Whist its in bits.....
cambelt (belt should be change every 4 years or IIRC 40k miles)
cambelt tensioner
as said above;
water pump, - make sure the new one has a metal impellor, not the standard plastic one SEAT originally supplied
oil & filter
definately clean out the intake manifold and EGR valve
