well, you can use 3 or 4 mm for dv and fpr, 3mm is better imho as the nipples under the inlet mani are tiny and 3mm is just a little tighter, but its up to you. if you look at my bay, i have used only 8mm and 3 mm.
the 6mm in my bay you wont need as it for my mbc
infact get 1 m of 6mm. this is to go grom n75 valve to charge pipe, i did use 8mm before but 6 is a better fit.
so your list should be
2m of 8mm
2m of 3mm
1m of 6mm
