What pipe is this?
don shaleone
146
Coventry
Did mine today the lugs were both knackered, but when I put my new pipe on it weren't as tight as I thought it would be but only time will tell I'll check it soon.
irishmanr26
382
Ireland
Sorry to dig this one up again. I have the same pipe blowing oil out of it. It had been fixed temporarily a few months back (I forgot about it! ) with a screw but its coming loose again now. Will I need to replace the hard plastic pipe that it connects into as well (is there a part number for this?)
dgjdrummer
Part-timer
Nov 5, 2011
1,310
Wrexham, N. Wales
The plastic pipe "should" be fine unless it's obviously damaged/warn. Replace the hose or just the end connector, you can get them cheap enough on eBay made out of billet aluminium that don't wear like the factory sort do. Also worth changing the C-clip as well while you're at it, a new more rigid and squarer edged one will help!
