What part no is this (is it the number written on it?)
ScoobyJawa
Achtung!
Oct 2, 2002
449
Liphook
I'm guessing this is the reason my car has been going into limp mode!!
picture.php
Anyone know the part number and what it is?
ScoobyJawa
Achtung!
Oct 2, 2002
449
Liphook
Cheers Guys :)
I didn't get the EML light on but everything was fine until yesterday when the car kept going into Limp Mode :( Might be unrelated, change and see I guess!
ScoobyJawa
Achtung!
Oct 2, 2002
449
Liphook
Just for info checked my error codes and got:
17544 p1136 intermittent - Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
17705 p1297 intermittent - Connection turbocharger - throttle valve pressure hose
Going to be replacing the breather hose, n249 bypass and getting the stock dv off there for a Forge 007.
Will check other hoses and clean MAF while I'm at it!!! Seems like they are mainly vacuum related.
Hamzilla
352
Watford, Herts
I have the 17544 error also although cannot see any breakage in the top hose so must be the one under manifold/dipstick area, as I can hear hissing from there.
INA do these hoses too I think. Trying to determine which is better quality between SFS (branded as Awesome) and INA.
AwesomeSarah
Forum Sponsor
Mar 6, 2006
727
Hi
The Awesome ones are also lined too , so the oil will not cause the issue to happen again
Sarah
ScoobyJawa
Achtung!
Oct 2, 2002
449
Liphook
Ever wish you left stuff alone :censored::rolleyes:
Started car and had a listen - massive whoosh noise from under inlet constantly. You guessed it that one had gone too - in a big way! :cry:
And then taking that pipe in the pic of the car, I took the top off the other pipe that goes into it off alone with some flesh out of my knuckles so I gotta get that one too now :shrug::headhurt::blink:
On the bright side when I've done the bits and bobs I should see a big difference (I hope!)
Dec 6, 2008
612
Shropshire
No because I replaced mine before I realsied you could get silicon ones.
I paid more than that for a genuine crappy seat one :cry:
Mine hasnt gone yet but will more than likely get replaced with one of these. I was just wondering of the quality as they also sell TIP's for £80, doesn't seem to be as many options on TIP's for the AUQ engine especially of the 'cheaper' options
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
for 80quid mark, look at the ths tips for lcr or lc.. good quality gear they manufacture.
dogbone and engine mounts are quality also.
i replaced the above said hose with ebay silicone and it worked very well.
Dec 6, 2008
612
Shropshire
Yes THS ones seem to be well recommended, trouble I have is that I havent found anywhere quoting them fitting the AUQ engine even on THS performance website.
