I Have A 1997 1ltr MPI and am gettin around 30 MPG and a think this sound low. what do you guys get and if 30 miles is low and 1 no what could be coursing it ?
Steve
Steve
-Does it get serviced often? Got done just be for a got the car about 3 mounth ago
-Are the tyres inflated correctly? 30 PSI
-Do you use cheap fuel or good stuff like shell? Only use 95Ron been told no to put the V Power or any think in.
-Do you ever use fuel additives to clean the fuel system? No, What Shoud a Use And How To A Do it ?
-Has the airfilter been changed? Yea, A Have A GREEN Air filter on it.
-Has the fuel filter been changed? No How Do A Do This ?
-Has it had new sparg plugs? Yes Only Done this a 100 Or so Miles ago.
-Does it perform as it should? A think It Does But Its the Only Ever arosa A have Been in..
Thx for the help
I use forte fuel treatment. Its very good. But you cannot buy it from retailers. Its only supplied to garages, but i get it since my dad is a forte rep.
Im not sure what elese you could use, i only use that as i know it works.
The fuel filter is behind the offside rear wheel. Ive not changed one so i carnt help you there. There are clips to clip the filter on and off but im not sure how you would stop the fuel from getting out unless the clip stops it, im not sure.
Do you drive it quickly? i know its a 1.0 but u know what i mean.
I see you from sunderland, local (ish)
yea a drive it quickly but when a drive it slow or on a mota way a always seem to get about 30ishMPG.
am from houghton le spring... were u from lol ?
I have an old Arosa 1.0 too - I can usually get around 250-280 miles per tank, so about 40mpg.
I once got it down to 27mpg by having a fully laden car and overtaking people
Hmm, sounds like you may have a problem somewhere, as yours is the same age and engine as mine...
