what is the best Compression Ratio 1.8T
M. Khodairy
60
KSA, Khobar
For Seat Leon 1.8T 20V, 180 HP AUQ
What is the best CT Ratio for the pistons to be used
And is it possible to use 83mm pistons in the engine without any machine work ??
M. Khodairy
60
KSA, Khobar
When you say best compression, for what use?
im about to upgrade my engine and the hp i wanna get is 350+
i'm not sure if the OEM engine internals can handle this much power
so i have to chnage everything inside
i have been browsing and reading n got some good internals
my OEM sizes are
9.5:1 with 81mm pistons
i was thing to to go with 9.5:1 and 83mm
so i was wondering if i need to do any machine work to my pistons block or it's just gonna fit smooth
besides i've seen some pistons with 8.5:1 CT, r they better for kinda HP i need
plz advice cuz i'm lost really
:D
Bouncerbeater
Old enough to know better
Mar 15, 2013
1,303
Gloucestershire
Looking for that kind of power will require lcr compression ratio of 9.0:1 for sure stock AUQ compression ration would probably be a bit high for the figures you are chasing. Are you going big turbo or hybrid K04 ?
M. Khodairy
60
KSA, Khobar
well i'm thinking of GT30 but if K04 would do it the i would go for it
yah Octan 95 we have here
in your opinion, you think 9.5:1 is a bit high and i should go lower yah
Bouncerbeater
Mar 15, 2013
1,303
Gloucestershire
I would say that running lots of boost usually means lower your compression ratio. 95 is standard unleaded here, most people use 99 on a modified car.
