DEAN0
Old Git
Feb 1, 2006
5,410
Preston - UK
Deleted stop/start on my Cupra300 what a relief as it was doing my head in. Debating upping the Diff setting but think I will put some decent tyres on first and see what I think.
Did you use the temperature or the voltage method for this and what numbers did you input ?
bega
205
I used voltage method and works like a charm.I think 7,6 V setting is fine if I can remember :)
Sent from my G8441 using Tapatalk
leonfr184
68
9
Gave her another wash after two days of road ****
Sent from my SM-G935F using Tapatalk
DEAN0
Old Git
Feb 1, 2006
5,410
Preston - UK
Ok thanks. They must of got rid of the setting then as mine doesn't have it, only got the car this week, has digital dash so a 2018 build.
You might need to run the car in the "individual mode" where you can select the levels of different items rather than the car selecting them.
Wings988
509
60
Derbyshire
Not on my car, the only selectable options in individual mode are as follows: DCC, Steering, engine, front differential lock, air conditioning.
Looks like they've deleted the option to turn down the soundaktor, I'm very annoyed as was looking forward to being able to do this as my 280 couldn't. Now the 300 seems even louder in sport and cupra mode :wtf:
TallTom
70
Just ordered lots of car cleaning products in preparation for the cupra arriving next week!
DEAN0
Old Git
Feb 1, 2006
5,410
Preston - UK
Invest in one of the softwares that allow you to do it via the OBD port ( OBD11, Carista, VCDS etc )
Or see if there is someone near you that can do it for you.
Alternatively - reach under the wiper scuttle and just unplug it.
bradleymarky
75
Huddersfield
How did you work out what it was? I’ve got a rattle on my passenger door... pies me off something rotten!
theres a large black plastic panel inside the door that rattles, I used sticky foam to cover the corners and also went over a few bits that already had manufacture foam on. It’s a pain to do and you must be a little brave but I can turn the radio down now.
I was going to do a “how to” but was getting annoyed, had to take it off again the following day because a small bit of plastic had found its way into the door and was moving about when I accelerated, I just removed the speaker and pulled it out.
