What battery in 2 button key?
stepdavi
Hello,
My battery in my 2 button standard key is low i think, but im scared to open it and read what bettery it is incase it loses its memory, i only have one key so reprogramming out or manual is not possible, can someone help or should i just man up and take my key apart
NickT
429
LB, Beds
Mine in my 2-button fixed key (non-flip) for my 2001 LC are 2x CR2016.
dan boy
198
loughborough
Hello,
mine is an energizer cr2032
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
My key is a non-flip standard 2-button key and takes a single CR2032. It begins to look as though there are two types, and you have to take your key apart to find out which. 2xCR2016 will give 6V, one CR3032 3V but more energy capacity (longer between changes), so you have to replace like with like.
TimJK
Audi Techie
Jan 10, 2009
435
Norwich
www.eacruise.co.uk
they are easy to take apart, just slide it apart with a small screw driver and then pull the bottom piece apart, if anything less than 3v's will require replacing
