Welded intercooler hardpipe material and routing
Ronin225
4,652
22
Worcester
Tim, any progress with this?
Or did you give it up?
Still planning on doing but need to finish other bits to allow room
Also need to uprate engine mounts first try and keep engine movement to a minimum (maybe some THS ones , jamjay)
Have pics from Phillc's car of proposed route, will be fabricating a new charge pipe with a downward bend at the end and no DV port and angled N75 take off
Its all plodding along but the supporting work for this is still being done
Ronin225
4,652
22
Worcester
Also found a core thin enough to fit behind crashbar and extending upto bonnet catch height but not too wide or with too large end tanks
Hopefully the fabricators can add angled inlet/outlet connectors to aid with the new route
The above core will be similar volume to the large race forge one too
