Welded intercooler hardpipe material and routing
Ronin225
4,652
22
Worcester
Possibly not in the right section so mods feel free to move
Will soon be doing a FMIC install on my leon but i dont want to run the pipework down the original route
I plan to have a shorter smoother route and plan on welding this pipe together with silicon joiners at cooler and charge pipe/ throttle body only
Most IC kits contain only aluminium pieces of hardpipe but all one piece pipe routes i have found are done in stainless, is there a reason for this?
Obviously the stainless will be both harder and tougher than ally so would ally need to be thicker walled to compensate?
Are there any reasons i have not found ally equivalent?
Due to charge temps, especially if remapped would ally welds fatigue over time and crack??
Could it anything to do with different rates of expansion in the 2 materials, as ally expands much more?
Any metallurgists here or people who know why??
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
DON'T use stainless steel, it weights to much and cannot dissipate heat as quickly as alloy.Most kits that have longer pipe with more bends use stainless as it's easier to work with and probably cheaper. Buy the alloy bends and weld them together, it's harder to weld but the results are better.
Ronin225
4,652
22
Worcester
We have a coded ally welder at work so i am going to be cheeky and get him to weld it
Wayne i will be coming off the cooler into bends almost immediately so it almost runs straight down from the end of the charge pipe (Again i will be remaking this with ports to suit my setup where i want them)
On the cooled side i plan to use the upward run as the MAP sensor part too, with a weld flange and DV port.
Will get some pics when i start mocking it up but got to relocate battery and do new TIP first
Ronin225
4,652
22
Worcester
It will be a very custom install so if a bit of undertray has to come off to suit, so be it but hopefully not
Just looking through some pics and elbows may even end up welded straight on cooler
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Tim, I was looking at my intercooler last weekend as the bumper was off, and i looked at the route you said you where going to take, it wont hit the undertray, but he bends are tight though i thought you get the best flow from flowing bends rather than tight ones :shrug: still good idea on the all in one pipe work so i might be needing some help when your ready :p Its going to be off again this weekend if you want to have a look. (The bumper) Also thought it an idea to weld to the intercooler and have the flexy silicon joint at the tubo and the throttle body.
Ronin225
4,652
22
Worcester
Got to work saturday morning, big periodic inspection of air receivers, oh joy but if you still have bumper off at 1ish i will have a gander
I did think about welding onto the cooler but i would make it impossible to install and being as the cooler is mounted to the frame and the engine other end it needs some flex otherwise it will crack the welds
Hopefully this new route isnt to tight as it will leave a large aperture at the side for an oil cooler
Ronin225
4,652
22
Worcester
Do you still have that piece of tube or offcuts from your FMIC install as we can see if dimensionally the pipes will fit before i get a kit of them
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
@Ronin225.
I would be very interested to see how this goes, from me the points of concern would be:
What cooler are you using, size?
What are the inlet/outlet sizes?:
Avoid where ever possible sharp bends, if you have to go a longer route and but its more of a sweeping bend, then this is better.
What size piping are u going to use?
Leak test all your welds.
Are you relocating your battery to the boot or just moving it slightly?
Sorry for all the questions!
Ronin225
4,652
22
Worcester
Robbie,
Battery is being moved to the boot and gigantic filter taking up freed room, also allows catch tank and possibly swirl pot
I havent chosen a cooler but was going to look into route as this could affect size, maybe shorter but deeper to compensate, looking into branded coolers for their efficiency and R&D not cheap ebay crap
Inlets and outlets will be 63mm ( 2.5") and piped this size throughout
I will also be fabricating a new charge pipe with elbow at front end, no DV port and a smooth 90 degree bend for N75 to stop the kinking/splitting problems
Welder at work is coded and only ever welds ally 8 hours a day so is pretty good
Cool side pipework is most important here as in the run upto the throttle body i want to incorporate the DV port and MAP sensor (have asked no-one thinks changing its orientation matters)
Ronin225
4,652
22
Worcester
Bit of an update
A work colleague brought an aluminium 2.5" bends kit from a local company seem good quality and have a wall thickness of 1.5mm or 2mm ( cant remember)
Either way very sturdy pipe and not easily bent or damaged, this is what i will use
Popped over to see Phill and his partially disassembled car and figured out a relatively smooth route (cold side will be a ballache though)
Now i have measurements i can find a core to suit
However before this i will need to fabricate a new charge pipe in 63mm not the standard 57mm
I have some pics of proposed route will try and get them up soon
