Weird knock!
May 22, 2009
788
South Wales
Hey i am just wondering if anyone knew what has gone on my car!
it makes a clunking noise when is accelerate and braking and occasionally when i am turning!
anti roll bar bushes mayb?
May 22, 2009
788
South Wales
anti roll bars clonk on bumps more than anything.
id guess top mount bushes maybe even lower arm bushes.
what model ibiza do you have?
I have a facelift FR tdi! my mechanic has taken my car for a drive and said its either the top mount or lower arm bushes!
wat is the best replacement for both?
as i said it could still be a cv joint most bushes top mounts cv joints all make very similar sounds but some are louder than others and make different pitch sounds so its impossible to diagnose online without hearing or feeling it for yourself,reading off a website is never going to diagnose a problem with bushes etc.
tony_tigger
yeah not trying to get into an argument, just personally always known such a knock to be a cv joint first...
Rob_B
Newbie
May 20, 2004
20
the front wishbone bushes need to be replaced wit tdi bushes as these are solid unlike the rubbish standard items. i got mine from Seat for £10 each. buy genuine ones only
Cal91
1.4 Powerrr
Mine has similar, but more of a knock and squeak. My car has only done 16k and still under warranty.
It's getting louder over time. Plus now if I turn my steering full lock and the ground level changes (say getting onto my drive!) it makes a horrible grinding noise! Sounds like the wheel is rubbing on metal.
Gonna get this checked out soon. Any idea's? Same thing maybe?
Rob_B
Newbie
May 20, 2004
20
well the wishbone bushes squeak at first, then start knocking over bumps. they are a poor design and you can see why they fail. if you look under the car and look at the bush, you will see what condition they are in.
