its more than likely the boot seal, i had all the side panel off today to try and source the leak and its all pointing back to the weld joint and the boot seal, ive taped up the weld and put a strip of tape down the entire seam ot the spot welded bit which the seal pushes on to
time to sit and wait, see what happens, i'll let you know
i doubt its the hinge, ive had a good look at that and also the srips on the roor its not from that either,
