Hi,
Has anyone else had the following water leak. Have searched but can't find reference to it (amongst the hundreds of references to the rear washer line leak).
I've got water collecting in the offside rear of the boot. Have taken the trim off and it's collecting in a cavity below the black plastic wing vent panel (don't know the proper name for this). It's a 10cm square plastic panel with a grid of small plastic flaps in it which preseumably vents air out of the cabin. It's underneath the bumper on the offside rear wing.
This could be the culprit, or possibly it could be the seal around the rear lights. However I sprayed all around with a hose this weekend and couldn't replicate the leak. Perhaps it only happens when driving with water thrown up by the tyres?
Does anyone else out there recognise the symptoms (before I waste time taking unecessary bits apart). Someone must have had the same problem.
Car is a LCR btw.
Thanks,
Adrian.
Car is a LCR btw.
Thanks,
Adrian.
