Feel said:
Mike & Bill - it *should* work fine. The 3800/3900 might be "old" but they're good little units. It's a cheap enough solution (if you have a serial ODBII cable) to try it and see...
Edit: If you're both at Westec on the 3rd, get the software downloaded and installed and you can try my cable...
will do :cheers: :thumbup:
Thinking about finally investing in a 1S.
Is it okay to use the standard water bottle? Along witht he standard liquid?
Or would i need to fill the bottle with only water/meth?
your washer fluid is made up of 25-50 % methanol/ethanol/isopropanol anyway so it'll be fine for the engine, all work as det control methanol being the best.
I found the wipers got shafted quicker(became brittle) with the 50/50 mix. lol :whistle:
personally im p8utting an alu water tank where the battery used to be, alu shouldnt conduct heat
dont forget the pump as to suck the water out of the tank.... and they advise pump is lower than tank for aided gravity fill...
