water bottle motor question
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
hey, quick reply would be super!
on the washer bottle motor.. which one is the rear, and which one is the front water exits??
there is a black one, and a white one. i stupidly removed it without checking, and i'm moving the bottle into the boot, and am only connecting the front washer jet, and blanking the rear you see..
thanks
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i'm almost sure white is rear if its a double outlet one
if its single outlet x 2 pumps it wont matter which
if you are putting it in the boot why not just join the front pipes together and use the not needed rear pipe to supply the front that way you could even wire up the rear washer to activate the pump and save piping and wiring too then
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
you read my mind Fl@pper ;)
i've used the pipe for the rear washer, but created my own wiring, as everything is currently out of my car anyway, so it wasn't too hard!
thanks a lot for the info :)
