Hello,
For several years I had some problems with boost on my ibiza and i recently decided to try to solve them, but i need some help.
My specs are revo stage 2 with all the stuff needed (4b fpr, larger downpipe, ...) and a forge FMIC.
The most recurrent problem is a requested boost which is not matched at "high" rpm (after 5000), a relatively low maf values (don't really go a lot above 150 g/s), and bad RR results against others ibiza same day same roller (and sometimes with less modifications on some of the others cars).
I have visually checked for leak (found nothing), changed the MAF, tried with a known to work N75.
At the moment :
- the achieved boost is well above requested at mid-range (nearly 1.4bar when 1bar is requested)
- but under at high rev (max 0.7b when 0.8b is requested).
If i remember correctly my wastegate actuator rod screw has been messed up some years ago when testing for a solution, and is not in the default position (changed to add pre-load on the spring).
I think it can explain the really high difference between requested and achieved at mid-range, but if i put it on default position the difference at high rpm is really worst.
Today i decided to down the boost using my sps3, electrically unplug the N75 and take out the car for a ride to check what is the maximum boost (determined by the WG actuator spring setting if i'm right).
Here is a log of block 115 :
First question is : what is the default pressure at which the actuator spring is set ? I though it was 4 psi ?
Second question is : am i right in thinking the boost should be quite constant above the entire rev range, and that i may have a weak spring in my actuator ?
And the final one :
if it's not the actuator what can it be
Thanks for your help !!
PS: sorry for the bad english writing.
At the moment :
Code:
rev/min Req Boost Boost Relative boost
rev/min mbar mbar psi
2160 1600 1040 0,44
2320 1590 1170 2,32
2480 1580 1300 4,21
2680 1560 1350 4,93
2880 1530 1350 4,93
3040 1520 1340 4,79
3240 1520 1340 4,79
3400 1520 1340 4,79
3600 1520 1330 4,64
3800 1520 1320 4,50
3960 1510 1330 4,64
4160 1510 1320 4,50
4320 1500 1310 4,35
4520 1500 1300 4,21
4680 1480 1290 4,06
4880 1470 1280 3,92
5040 1450 1280 3,92
5200 1440 1280 3,92
5360 1430 1280 3,92
5520 1420 1270 3,77
5680 1400 1260 3,63
5840 1380 1240 3,34
6000 1360 1240 3,34
6120 1340 1240 3,34
6280 1330 1230 3,19
6400 1300 1220 3,05
6520 1290 1220 3,05
And the final one :
(doesn't change so much).
