Warning light???
chrisboyle999
MFD3 for sale, inbox me.
Nov 28, 2006
1,838
Geordieland
i would have said;
red - brake fluid warning (but you get a written warning with that too)
amber - tyre pressure minitor
pics of an fr i know, but theyre pretty much the same. see it on there?
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
is it to tell you a bulb is out? have your xenons been replaced with lhd xenons? if not the different current draw of halogens and xenons will be causing the blown bulb warning light?
DannyC87
Mar 4, 2008
3,459
hmmm... if it was a bulb warning indicator it should be instant. have you checked you don't have a headlight out or any light out for that matter? might be worth plugging into vagcom to check for errors?
Marshall
3,256
Bonnie Scotland
This light came on mine it is in the rev clock and its a bulb failure warning. Mine came on and it was a front foglamp not working but they were not on at the time, so it must run a test on startup. Kev
Tfsi_Mike
2,387
Doncaster / Germany (Army)
Aaaaaaaaaaaah,
My fogs were unplugged when i fitted the splitter. Also I think there MAY have been a little water ingress from the headlight washer tube that was also disconnected.
