Hi everyone,
I recently got a great deal on used VZ5 rims with factory 255/35/20 Eagle F1 tires. After doing a test fit, I noticed that when the wheel is turned fully to either side, there’s only about 2-3mm of clearance to the back plastic cover. Is this normal, or could it potentially cause any issues?
Before I had stock 245/40/19 tires and stock rims, and clearance is around 1cm or even more.
Thanks in advance for your input!
