hey guys i have my leon for a year now and at ramdom times it lights up the epc and esp and gets me into limp mode . some other times it just lights up check engine light .The car with the ceg light only operates ''normaly'' .I have changed the maf sensor the camshaft and crankshaft sensor . have a pcv delete. I assume my vvt is on its way out because the car wakes up at 3500rpm also i have an intermittent ceg with a code retarded timing.
Does that ever happened to any of you?
Was the vvt solenoid the problem??
Thanks guys!!
Thanks guys!!
