Vr6 2.8 Conversion!!??
greekboy698
I have been offered a 2.8 golf mark111
and i was thinking of putting it into my 2000 ibiza 1.4s
is this hard??
anyone done it before know any extras i will need??
thanks!!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
chassis is the same....
if you have a complete donor car, it'll be a walk in the park (with oil)
remove engine/box from ibiza & replace with that from the golf. you may as well fit the wider front wishbones & hubs to get the bigger brakes too.
take the wiring loom from the golf & fit it to the Ibiza (engine side only)
greekboy698
cheers mate
are the engine mounts the same??
if nto know any where i can get dem?
cheers
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
i think that is very needed. 1.4 brakes are cack and wont stop the car. also you will need to upgrade your current suspension as a 2.8 engine is a darn sight heavier than the 1.4!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
they're not a whole lot better as 288mm brakes really... but better than 239's!
Rick1.8t
150
Willl you be able to use the stock exhaust manifold/downpipe - or will it hit anything?
You may want to think about suspension too as this engine will weigh loads more than the 1.4 - and a lot more than the 1.8t too i expect.
Sounds like an interesting conversion, i turbocharged VR in a cupra car would be lovely, im not sure what it would do to the handling though as it is a big old steel lump.
Good luck with it if you go ahead, it would make for an awesome sleeper for sure!
Rick
Rick1.8t
150
20kgs isnt a great deal if that is correct, move the battery to the boot and reduce the washer bottle size and it wouldnt be that noticable i wouldnt think.
Jon@VAGWORX
Take a look here mate - http://mk2vr6.com/board/index.php
Baisically the same conversion. You will need to upgrade fuel pump and cut the chasis leg to physically get the engine in, but everything else will be a 'rob off a mk3 golf' job.
Vr is 45kg heavier btw.
