Very slight knocking noise at idle
diddles
289
Hi, I've noticed my LCR makes a very slight knocking noise at idle, sounds likes it coming from around the lower belt area, is this normal? Anything around that area which commonly makes a slight knocking noise, will get a video soon. Thanks
diddles
289
Thanks but it sounds lower down, will need to get a stethoscope down there think. Any other things commonly to knock around the lower belt area?
diddles
289
I hope not, its not loud, would of though a bent rod would be noisy all the time not just at idle?
diddles
289
Could be but I would of thought I would of got ticking from the cam adjuster If the pressure was low, ill have to get a video.
googujube
LCR225
Jan 1, 2013
368
York
Had a piston ring about 20 pieces causing a slight knock on idle..well I'm assuming it was the ring anyway. No knocking following rings being replaced..the rods were ok. Guess it could have been a belt issue of some kind.
SWANSWAY CUPRA Dealership
