VCDS errors
ile
34
Hi,
if someone know and can help or tell me what is wrong on that errors
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0103
Shop #: WSC 00049 770 00244
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 4385FA0BCA95D1939E-8016
3 Faults Found:
20740 - Databus
U1123 00 [008] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Reset counter: 12
Mileage: 135544 km
Date: 2021.06.26
Time: 14:42:53
Motor status: 00
System status: Waiting for start request
Supply voltage: 12.00 V
Temperature: 34.0 °C
KFC: 51
KFA: 00 04
Freeze frame conditions: 20
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 12.17 V
uAdSensI_SwitchedKl30_xdu16: 12.16 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
20228 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 12
Mileage: 135544 km
Date: 2021.06.26
Time: 14:42:53
Motor status: 00
System status: Driving mode
KFC: 4F
KFA: 00 04
uioUdNotFilt_xdu16: 12.30 V
uAdSensI_SwitchedKl30_xdu16: 12.31 V
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 12
Mileage: 135544 km
Date: 2021.06.26
Time: 14:42:53
Motor status: 00
KFC: 4D
KFA: 00 04
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 DA HW: 04E 907 309 AC
Component: 1.4l R4 TSI H21 8231
Revision: R7H21---
Coding: 01190012232419080000
ASAM Dataset: EV_ECM14TFS01104E906027DA 001011
ROD: EV_ECM14TFS01104E906027DA.rod
VCID: 66C3039F9967C4BB59-8032
Center armrest control head 1:
3 Faults Found:
17158 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
12888 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
Readiness: 0000 0000
same errors are stored on 2 places
thanks in advance
black_sheep
1,251
587
I imagine that most of the issues are because you are using an interface that is not compatible (Hex V2 or Hex-Net required) with the controllers and/or software that is out of date. Do you have a genuine cable?
ile
34
Hi mate , thanks for answer, no cable is only from aliexpress i do not have genuine cable
