Vag fault code 01137
Stevesids
Hello. I have a seat Leon fr 170 tdi. The engine management light is on at the minute with my fault code reader I have vag code 01137 my book says its central locking fault but I have read on some forums it is the dpf pressure switch the dpf on my car regulary asks for the regen instructions to be followed despite the fact I only use it on long trips. I have only had car 2 weeks and it has had this problem 3 times and once went into limp mode which I had to get dealer to sort can anyone please clarify what this code is as the dealer wants another 60 quid just to look at it
Stevesids
Hello thanks for that yes it was exhaust pressure sensor if I were to get problem again is it ok just to fit sensor if a regen is not required. Or do I have to get it adapted to ecu as dealer would have me believe
philip mcneilly
hi have same problem 01137 code and engine management light on as well, so hopefully a new exhaust pressure sensor fix it?
