Vag com run and done
Apr 24, 2007
985
W. yorkshire
Right this might be a no brainer but here goes
I have run the trail version of vag com and it ran through what i believe to be the process (which too hours)
now once it has finished all that it says in the window is something on the lines of
address 15 air bag not checked
now i know that it should say that as i did not tick the check box for it to check the airbags, but does this mean it has completed the process and found no errors or problems.
Im sure i will get the usual obligatory statements but i've never run it before and was previously having problems with it so just want to be sure its running properly now
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
So what command did you use to scan for faults?
There should still be a report from the check of all of the controllers, even if it just says "no faults found". I am not sure why it took hours as it should only take about 1 minute max.
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Yeah, there will be a bit more info than that, something like the below:
Address 01: Engine
Control Module Part Number: 8D0 907 558 B
Component and/or Version: 1,8L R4/5V MOTR HS D02
Software Coding: 04001
Work Shop Code: WSC 06435
2 Faults Found:
01120 - Camshaft Adjustment 1
04-00 - Mechanical Malfunction
17916 - Idle Control Sys: Upper Regulation Limit Reached
P1508 - 35-00 - -
Readiness: N/A
But ideally without the fault codes!!!
Try using the auto scan command, I don't think you can choose not to check certain controllers though. It will open and try all of them. It will also try some controllers that you don't have!!
