Vag-com and vista
MrNailer
81
hi guys have a cable and ross software some reason i cant get it to work when i first tried it read all engine codes then said it had to shut down down anyone got any ways of making it work with vista? please help thanks nailer
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
I've been trying for about 6 months and still cant get it to work, even tryed 2 different cables..
flappy
Ferociously Rapid
Mar 28, 2007
219
I installed mine yesterday on Vista, just followed the instructions in the sticky and it worked :)
MrNailer
81
got mine off ebay for under 20 pound and just cant get the flipping thing to work someone help run as admin still freeze`s up and has to shut down why the hell???
and for the cable driver it picks it up as a high speed converter not vag com cable?
MrNailer
81
i thinm my problem is the usb cable driver as it picks it up as high speed converter and not only that when starting vag com up and going to test ony says found on com 3 yet it should be USB?
MrNailer
81
well i had big big problems am using 409.1 and cheap ebay cable and if u have already installed the cable once before not worked you have problem did same as me and messed up all com ports in dervice manager, what i did was restore windows before i installed then reinstalled 409.1 after that installed cable with the ross tech driver witch come on a disc and was exact same!
picked it up as high speed (something) converter after that went to dervise manager and went to coms and lpd! after that set it to port 1,2,3,4 thats not in used, open vagcom(409.1) options then selected port i choose in dervise manager after that saved and taken it to car once plugged into car i clicked tested then it said found interface(the car) then vagcom worked fine but kept freezing up after that i Restarted and works a dream now hope this helps!!
