dlewis
Hi all,
Loads of problems with my 1.2 12v, the usual roll bar bushes, rear washers jets, window mechanism failure. The latest problem was engine stalling and stuttering in low revs. Took it to a reputable garage and they said it was the spark plugs or coil pack so I replaced them both. Just after the coil packs and spark plugs change I drove 12 miles then the battery light flashed and powering steering light came on, I lost all power steering (a mile from my home). Turned engine off and checked under bonnet all seemed ok, started engine and power steering back for about 300meters then the same fault. Got home safe but need car for work, any ideas on problem.
Thanks!!!
Thanks!!!
