Urgent Help Needed!
dlewis
Hi all,
Loads of problems with my 1.2 12v, the usual roll bar bushes, rear washers jets, window mechanism failure. The latest problem was engine stalling and stuttering in low revs. Took it to a reputable garage and they said it was the spark plugs or coil pack so I replaced them both. Just after the coil packs and spark plugs change I drove 12 miles then the battery light flashed and powering steering light came on, I lost all power steering (a mile from my home). Turned engine off and checked under bonnet all seemed ok, started engine and power steering back for about 300meters then the same fault. Got home safe but need car for work, any ideas on problem.
Thanks!!!
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
think it could be a steering rack sensor being loose, think there was a thread about it before. Try a search I do believe there is an answer on here somehwere, failing that wait till the bloke with the fault I am on about gives some input into this
lesz42
tbh, set fire to it
sorrry!:rolleyes:
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
welcome to the site you two! :wave: take it back to the garage and say what has happend they may be liable for the fualts but its doubtful
dlewis
Hi,
Garage diagnosed the problem, I carried out the work as it was only the spark plugs and coil packs. Could be a seperate issue but just after doing the work, I'm not sure? I've read the other threads and it could possibly be a sensor, doesn't seem like I can check the hydraulic fluid level (cant find it in manual or in engine bay). Maybe if I connect to Vag Com and diagnose will get more info.
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
fluid is under the battery is hard to check. Also les42 :S thats a really stupid first post why not say what u drive etc instead of just posting crap. :ban:
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
What he said, there is an intro section but seems you have done it...
What do you drive lesz42???
dlewis
Thanks Guiness, will get it diagnosed 2moro.
Les42 is a mate helped me find the site, feel like trorching it at mo.
(he drives a saxo) he he he!:)
tuckerjuk
22
Glasgow
Sounds like your throttle body is clogged with carbon deposits which cause the revs to fluctuate and sometimes the car will cut out which if it did you would lose power steering until the car is restarted. Its easy to clean but you need the diagnosis computer to carry out a basic setting. Should be an hours charge at a Seat dealership
lesz42
hello all!, just joking, had, well only just in the week, a problem with the ecu on the saxo, so we (dlewis) and me. almost carless!
just helping dlewis with his nice ibiza, love the seat range of cars, anyway, nice forums here, one ? i have is, can you get a hayes like book for the seat?
dlewis
Would a loose alternator belt cause my powered steering to fail? when i turn engine off and back on again it regains powered steering, to me that says that the powered steering system is ok, unless its a sensor?
