Hiya
Sorry for making a new post but i have a problem with my car,
I thought it was all sorted, Problems were symptomatic of the ECU Relay and Fuel pump relay and also cleaning the Throttle body with some carb cleaner.
Today i had some problems where my car cut out and just wouldnt start for a while, when the car started it was all lumpy and running around 200 Rpm then it would cut out, This was after driving for about 15 miles with no problems, I got up to a roundabout and then the car died, Busy morning traffic too!!!
After getting it started i managed to drive the car but it would be very tempremental and kept cutting out.
I have now gone home and driven back and the problem didnt occur again
Very strange and all being tempremental!
The car is a 2.0L 8v GTi Cupra Sport
1999
I have replaced :
ecu Control Relay
Fuel Pump Relay
Dizzy Cap
Rotor Arm
HT Leads
Spark Plugs
Cleaned Throttle Body with carb cleaner
Do you guys have any Ideas whats up with it ?
Could it be idle control valve or a stepper motor ?
Really annoying as i need to fix it asap, I need to get to work and back daily.
Means ill have to take the bike and not really up for getting soaked (zxr 400 tho )
1999
I have replaced :
ecu Control Relay
Fuel Pump Relay
Dizzy Cap
Rotor Arm
HT Leads
Spark Plugs
