Uprating Cupra clutch
Blade
1,386
32
Seeking peoples opinion of a Sachs Race clutch - organic friction disc with heat trated cover. Have an option to fit this onto my K1. My tuner says they have a very o/e feel and will easily cope with 400bhp -420lb/ft
YIN
Leon cupra Mk2
Oct 6, 2003
904
Dudley
www.futuremark.com
I have a Sachs Organic its takes a bit of getting used to and is slightly heavier than standard but once i had done 300 miles it felt no different from standard
Jon
Blade
1,386
32
Jon
Thats what i wanted to hear, thanks.
Just so i know i,m getting a good price would you let me know what you paid - pm me if thats easier - ta
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
Ive got a Southbend stage 3 on mine, have a look into that. All the rage in the states.
Al
7,326
9
Blade - Is that with an uprated flywheel? Having heard some uprated kits, the flywheel noise puts me off somewhat.
Can you PM me info too though please.
Blade
1,386
32
Just the clutch. waiting to hear about the flywheel.
YIN
Leon cupra Mk2
Oct 6, 2003
904
Dudley
www.futuremark.com
Mine uses standard flywheel but needed a new one.Have drove a ed30 with single mass and didn't like it
Awesome Sachs organic £852 all in (organic clutch and cover ) or south bend stage 3 £1400 fitted
Backdraft spec Stage 2+ with Steel Flywheel - £895.95
Stage 2+ with Alloy Flywheel - £979.95
Stage 3+ with Steel Flywheel - £989.95
Stage 3+ with Alloy Flywheel - £1069.95 all plus £200 fitted
Midland VW £1300 for this one http://www.sachsperformance.com/EU/...orsionsgefederte-scheibe-mit-organischen.html
Blade
1,386
32
Standard flywheel is £276 .Another option which favoured on Mk5golfgti.co.uk forum is a http://www.racinglinetuning.com/ clutch who do a Sachs sintered clutch that works with standard cover and flywheel for about £500.
Thanks very much for the info. Spoke to my tuner today and he has fitted loads of clutches and not changed the flywheel. Apparently he has learned that the degradation you see on the flywheel happens to every standard flywheel and is no cause for concern whatsoever. Never had a failure!
RobH
1,547
West Yorkshire
hi just wondering bit of a noob when it comes to clutches, how do you know when the clutch is starting to go i mean is it totally obvious or just slight vibrations. this is pretty much my first high powered car so dont really know what to feel/hear for, thanks in advance.
Al
7,326
9
Put it in to 4th or 5th, floor it. If it starts to slip (ie revs increase and speed does not) then you need a new clutch. Engaging gears may also become harder to do.
