Uprated recirc, what's the benefit?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
This is what it says on the forge site
"Made from billet aluminium, this recirculating diverter valve dumps the charge-air back into the air intake system keeping external noise to a minimum. This increases both quicker throttle response and higher clamping load to maintain boost pressure more reliably"
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
the standard one performs well but it has a rubber diaphram which can split and will weaken with age.
the 007 has a piston instead of a rubber so it cant tear.
the forge works well but needs a yearly service which is easy to do, i found it prone to sticking otherwise.
the APR R1 is a diapham like the stock one but much more beefy if you wanted an alternative to piston derived versions
cant really call it a performance mod but you need a fresh one if its been working for 3 years and you suddenly make its job harder by remapping
