To answer the original question
Forge DV is sensible as the OEM Bosch unit is a known weak point, some people have run fine for thousands of miles without changing it but it's a sensible precaution.
Oil Changes as well as the recommend 10,000miles service consider one in between. If you don't want to get your hands dirty buy the oil yourself and get the change done very cheaply at a place similar to these
http://www.nationwideautocentres.co.uk/bookmotlocatecentre.asp my local one had a deal at the time like £45 for labour and filter (I supplied the Oil) seemed good to me.
Apart from that wait till the following expire then upgrade;-
Tyres - change the awfull Pirelli's to something handy
Pads - Change to Ferrodo DS2500's and do the work yourself it's really easy
karlosR said:
fast road pads are a good idea on a LCR, uprated discs wouldn't do any harm either!
Unless you go to 2 piece disks you will struggle to find an altenative to Brembo, someone said black diamond and EBC were going to do one (not sure they ever did).
Loads of places list them only to discover they are 312mm LC disks.
You'll be amazed what some decent pads achieve anyway
