I think that I read somewhere that if you remove the MAF connector and the car seems smoother, then that means the MAF is u/s or needs a good clean out (cleaning out with contact fluid would be cheaper to do first off if removing the plug improves things). Other thing seems to be that this MAF connector or the MAF wiring connector pins can get contaminated - so removing refitting a few times can clean them up a bit - maybe try this first, then try leaving this connector off if that fails. If it is the connector that appeared to be the problem then cleaning both the male and females pins then stuffing in some contact grease might keep the connects better for longer. Good luck, as I've said, this lot is not my brain wave, its just something I've read in www.briskoda.net
Thanks very much mate, i heard this too from another member...but the problem is its running fine now so i wont be able to know what the problem is if i attempt taking it out and seeing if it runs better.
im going to do everything suggested as per in this thread...service, clean throttle body, injectors...then get it Vag commed AGAIN and see what it says this time...
my reacurring EPC light has come on again its just like on thing after another!
