Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
helix is what i ran originally both organic & paddle, but disk life was shorter than I was happy with. spec has lasted longer with more power going thru it
The Stage 3+ is rated right over 500ft/lbs isnt it?? Would you say the normal Stage 3 (rated at 444ft/lbs) would be sufficient for up to 380~400bhp as torque should be similar.
Aye, was just trying to work out whether the + was worth the extra £100 or not as I can't see a point in going for a 535ft/lbs clutch when theres a 444ft/lbs option and my expected torque will be around 400ft/lbs anyway.
Think my clutch is starting to get a little tired (ibiza cupra). When it does go i want to replace the flywheel aswell (don't like the dmf's seen too many that have destroyed themselves at work). Would the package in the link below be ok with my car.
hmm, in a few weeks i`ll start my k04 conversion and im still searching for a clutch ;(
got EDT gearbox with 220mm clutch...
sachs perfomance, or spec? i still don't want to swap to 228mm
I've gone and got the Stage 3 228mm Clutch w/ G60 Billet Steel Flywheel. It's a loverly piece of kit and we'll soon see how nice it is to drive with it all I need now is to pick by box back up from dan-ish when he's finished fitting the diff!
