good old seat ive had problems with fans on rad secondary water pump not working i started getting funny smells i found a melted fuse holder on the battery and knackard battery
it happened after i left you
started playing and found the fuse was meleted the bottom of the fuse holder is a right mess that explains the water pump not working when i switch off i hope
I've had it twice now and the second time it melted the holder so i had to get a new fuse box bit and cost around £30 IIRC.
Just another common fault !!! tut tut
fitted the new part today still the secondary water pump is not working i let the car warm up untill the fans come in switched it off no noise from the water pump does the car have to be drivin before it works
