Unsure about sidelights
baconjamie
42
I am currently in the process of replacing my sidelights with white LED's on my '57 Leon Cupra.
Now I'm fairly new to this car so I'm looking for a bit advice before I go ripping my lights apart.
I appear to have 3 lights (https://i.imgur.com/2i6QtUR.jpg):
  1. Big headlights main one, Position 2 on the headlight switch
  2. Medium sized Bulb on the side, this bulb never actual comes on (This is circled in red)
  3. Smaller sized bulb, Position 1 and 2 on the headlight switch (This is circled in green)
The bulb I'm actually looking to replace the Smaller bulb with some white LED's which I have purchased:
Basically, my question is, am I doing this wrong? Am I looking at /changing the right bulb?
I have attached a video of where I'm going to change the bulbs, is it the right place ?
Hawkers
334
58
Norwich, UK
The white holder is the one you need, if you wiggle it you should see it move in the lense. This one just pulls out.
baconjamie
42
Update:
I seriously overthought this, it was a piece of piss; did it in 5 mins.
Just pull the rubber cover off; while the wires a tiny bit see if either bulb moves then navigate to each holder thing.
One tip I would give is, LED’s will only work one way in the ballast.
Leave the bulb out of its clip; try the light, then if it works out it back in. If not flip it.
